Cam Belt change
Hi all, I am due a cam belt change and I got quoted from a trader around £600 for everything, The normal garage where I go I just saw the guy and I was talking to him about it as its the first time he has seen my new car,
He said he would do it for £250, I know people say local garages might not do it properly, but I don't understand why if they are a garage surely they are qualified enough to do the job properly? They do it on every other car so why is it this car that's so different?
I not long ago started a new job and had to take a pay cut so before spending £600 on the car wouldn't have been an issue but at the moment the £250 sounds very tempting and I could afford it, If it needs doing as desperately as everyone suggests is it worth just going with my local garage so the job has been done?
Emma
  330i. E30 Touring.
Nope. Wait and have it done by someone who knows what they're doing.
Why's it £600 though? Plenty of traders on here do a cambelt and auxbelt service for ~£450..
Your quote of £600 include a dephaser?
Put it this way, I've yet to see one done by a local garage that I haven't had to correct.
People do not know how to do these properly, and the correct tools cost best part of £150, so he won't be buying them just to do the work.
If it helps, I charge £425.
Yeah the £600 included the dephaser, I dont think my dephaser actually needs doing but a lot of people seem to think i should have it done at the same time.
If he does have the correct tools then would it be worth taking it there or is it still a no no?
DrR
  VW Golf GTD
1*2 means 172/182.
If you're in the midlands go to Birchdown or BTM.
Trouble is your to far away! im in nottingham lol
I think it was £390 for just the cam belt and £600 for the cambelt and dephaser
Nottingham, go straight to diamond motors.
That is who I was in touch with and gave me them quotes! He was very helpful and like I say if I had the still got the old job I would have been straight there and getting it done at diamond motors.
Yeah the guy at my local garage said he uses genuine parts too... I'm guessing what you guys are saying is the tools to do it with.
So he's doing the job for free?
Yeh, the tools are 150% vital that they are genuine. Not just the cheap laser equivalent.
There are 3 tools that are needed, most garages use 2.
  182
There is more to the dephaser than what most think, like oil and filter change and seal kit. Not just the pulley itself.
The correct tools are a must!
Ok, so I'm I right in thinking you are suggesting to wait until I can afford to go to a specialist? Even though it is past being due!
  FF Clio 182
Garages like SJM and BTM charge £600 for a reason, if they could do the job properly for £250 then they would probably do it for that. Parts like Cambelt/aux kit, seals and dephaser come to about £300 as it is. So yeah I would wait or ask somebody nicely for the money...
  330i. E30 Touring.
Just get the belts done without the dephaser tbh.
It's only of late that people have been convinced to get them done with the belt.
  DON'T SEND ME PM'S!!
I had one in this week, that had been done by a guy who builds massive power Mustangs and other muscle cars, drag cars, circuit racers, all sorts. He couldn't have got it more wrong. Shows that it doesn't matter how good you think you are, if you don't know these engines then you are back to day 1 of school.
FYI, full retail list price on a dephaser pulley is £181, cambelt kit £150, Aux belt kit £72. How is he going to do it all for £250?
  FF Clio 182
But for the sake of £130 I would get the dephaser done. No point spending £450 getting all the belts changed then 4 months down the line your car sounds like a tractor and you have to rip it all off again... One thing on a car you never want to skimp out on...
I agree. I only do them when they're noisy, and i've had 2 come back ever. I let them soak in the part washer for as long as I can and it seems to help extend their life by getting all the old crap oil out
  FF Clio 182
Plus oil and filter...
Just in two minds about what to do, either wait until I can afford to go to a Diamond motors or get it done because otherwise im risking it snapping...
without wanting to sound condescending, if you can't afford to service it then you can't afford to run it. best to not use it until you can afford what needs doing
I think it was £250 without the dephaser
As said before I had the car and then took a pay cut not long ago which wasn't expected as I got a new job, Otherwise I wouldn't have bought a car I couldn't afford to run simple as.
Anyway thanks for the advice everyone has given I will get it down to a specialist asap
  FF Clio 182
Well according to certain members on the forum the belts don't ever perish so you could just reuse them as long as they been serviced correctly... ;)
I know, don't worry I've been there and had to take a car off the road for a few months when circumstances changed, on more than one occasion. IT happens unfortunately. You'll be better off in the long run if you can manage without it for a short time :)
Ok, thanks for your advice and help! :)
  AB182, Audi A5 3.0
Just putting this out there, others will have to confirm if this is viable or not...
As you tight on money at the moment, could you net get the guy to do it for £250, then if he gets it wrong take it to diamond motors to be timed correctly? I don't think you would need a new belt if it was done in a short space of time? That's way, you might get it done alright for £250 by luck, and if not you can get the timing corrected for another £150ish, bring you to the same price as what's normally charged?
dan etc will confirm if this is a really bad idea or not.
