Cam cover breather gasket
Car  Clip 172 cup
Does anyone know where I can find a gasket apart from Renault ? Nearly died at the price today many thanks for any help with this matter
matt
do not use blue hylomar on anything that needs to seal oil in.
I throw the gaskets away and use black automotive grade silicon
The breather at the top gets f**k all oil to wash it away, gets a bit of vapour and that's about it.
That should be fine mate, if not then you can buy it from Renault but it's more expensive.
I've done my cam cover with 5999 but we use it at work.
I've never put anything on my bolts tbh.
Nice one, thanks. Job for the weekend
Seemed like the gasket was in two parts when I took the plate off last time - or have I looked at it wrong?
£15 from main dealer but it's a metal gasket so it's s**t. Any good silicone sealant from a motor factor is ok. I just in the process of doing mine as it is leaking oil vapour
