Cambelt Questions (172)
  clio diesel
Hello,
Can someone tell me what splash shields should be present around the cambelt if you look under the front offside wheel. I looked at a car and you could see the bottom of the belts through the arch gap, so i am assuming that the lower belt cover is missing. Is this correct?
Also, i assume the front offside has the same arch liner at the front as on the nearside, a big 'L' shaped arch liner that goes under the front bumper?
Are there any other splash shioeld that should be down there?
  clio diesel
No that is missing, that must be why i can see the pulley, which i assume is the air conditioning pump is it?
Is the one that attaches to the tie bar all one piece with the one that fits under the bumper?
