Cambelt replacement
Car  A well built VW
Roughly how much for replacement on a 2002 dci 65 ? Is it advisable to get anything else done ie. water pump at the same time
mine was done 2 yrs ago. gsf had genuine reno kit for around 55quid. labour was abut the same
done :)
cheers jonny did you get the water pump done or is it not necessary
£55 for labour fingers crossed i can get it for that price
didnt need to get the water pump done. not much extra to do tho if you want it done whilst the timing belt is off
not done a dci in a clio,, but i've done belts on dci laguna 2's and megane 2's and they were both a doddle and not a long job.. so assuming you have the same sort of room in the clio i wouldn't be wanting to pay too much for a belt change on one
Laguna 2 1.9dci (f9q) is my favorite cambelt! so easy
Been quoted £230 or as recommended as the water pump is behind the timing belt £290
Someone else said not necessary to replace pump £230 or £280 if i want pump done
Anyone know the dreaded answer to the water pump question - is it behind the timing belt ? This seem a high price to others ? 3 hours work they are quoting
mate, take the stranraer ferry over to belfast, drive 15 miles to newtownards, theres a reno dealer there doin timing belt kit fitted parts and labour for 99 quid! i kid you not!
and yes, ancilary pump is on timing circuit :)
Yes the water pump is behind the cambelt cover and the alternator also has to come off to change it. Make sure they have the correct tools to do the cambelt because it has a floating crank pulley.
Once its all apart, have a look at the water pump, if its all ok leave it.
Christ prices seem to just get made up - I have one quoting me £157 to supply and fit kit but £130 for a water pump lol
How easy to do it yourself ?
