Camber adjustment
I have bought some of the K tec coilovers with built in camber adjustment. Can I adjust the camber with standard top mounts?
yes mate but the coilover unit will only allow you to dial out a certain degree of camber. if you wanted more camber you could buy camber bolts.
The built in camber bolts have lobe washers on the outside which maximise the slot either way, so new camber bolts wouldnt make it move anymore would it?
Never see many say on here about their camber set up.
ah ok mate. i thought you were talking about fk coilover units which actually dont come with camber bolts but i think the ones you are talking about are similar to vmaxx coilovers which come a with a camber bolt. basically answer to your question is that you can adjust camber with standrd top mounts yes
