Camber adjustment
Car  clio 172
Hi everyone i have camber adjustment bolts fitted to my front suspension and want to have a go adjusting them, does anyone know where there are and what they look like, sorry but i am not a mechanic!!!
Thanks Edd
Take it to Fred at BTM Performance, he won't charge you much to do it for you. Only in Garretts Green 0121 783 6692
If you need to ask where they are then I suggest you probably shouldn't be playing around with them as I'm guessing you don't have camber and tracking gauges?
Thanks for your help i have found images on the web, the problem is my camber keeps going out and need to know where the bolts are so i can work out why after getting the suspension set up after 2 days the camber has gone ballistic on the drivers side!!
I do have a camber gauge!
