the size difference is the whole point of why you get more camber, the strut hole rests on the bolt as you adjust it (unless you're setting the camber with the wheels in the air?) as you rotate it with the wheels on the ground the cam lobe pushes on the hub forcing it outward to give less negative camber
no need to insult me fella, its just the internet! We've setup race winning cars WITHOUT the washers, if you read the box they come in it states "Volvo/Subaru" they might be required on them, but IN MY OPINION you can bin them when used on clio's, also WIHTOUT the washers i believe you get more camber from my experience
no ill offense to you in anyway shape or form, i'm just sharing my experience with everyone else, if you don't like my opinion fair enough
your opinion is quite strong in this thread to bin the washers and this is wrong and bad advice. no one should listen to that and i feel strong about that but im not out to insult you so sorry for that. its impossible to get more camber without the washer if your setting them correct. you must be putting the inner tab in the wrong place. like i said it has to be opposite the cam lobe and no where else. no offence intended but please look at how they work again and see what you think. we can all learn something new and im sure you could teach me far more than i could you but at least be willing to give it a try.
Not if adjusted correctly, they are just meant to take up the slack between the slimmer section of the bolt and the shock.
Nail on the head.
