Camber bolts??
Car  CLIO 172 PH1
HI, I'm driving a 172 Ph1. Using Koni sport suspension with voland low down spring.
As i want to set a little bit camber to the front, i found that there are Eibach Camber correcting bolts at K-TEC. I have a little question is that, is there any side effect after using these bolts?? (Except the uneven tire wear)
Can it improve the handling of the car ? THX:boring:
Depends on what settings you go for, it's not just a case of fitting the camber bolts and away you go.
-1.5 seems to be about right for a good setup, or maybe -2 if you want a little more turn in however the car may tramline and you may see a little increased wear on the inside of tyre.
On a side note, I've got the eibachs and compared them to a set of H&R's and they're exactly the same (except you get a washer with the eibachs too).
You'll need to get the geometry done afterwards - adding negative camber will add toe-in. You want 10 mins toe-out.
