Camber bolts
Car  KTM 990 SD / S60 D5
Need to get my camber bolts fitted, will I have to have the wheel alignment done again once they are fitted as I only had it done a few weeks ago.
Yes you will need to re do your tracking, as adjusting the camber will throw the tracking out, as will lowering etc etc.
When you tip the strut with a camber bolt it moves the location point for the steering arm slightly and hence throws you tracking out, its not as big an effect as on some cars like for example a corsa b where the steering arm is located much high up the strut but its still enough that you will want to get it re-tracked.
