Camber
  Ph1 Sport
I have just spaced my rear 25mm and they are just rubbing on the outside of my arch, i was wondering how to go about camber and where to get the bolts from to do so, also will they fit my coils..
Thanks, Baz.
If you want camber, either buy some camber shims, or space out the stub axel with washers ;)
Where abouts can i get shims from for a reasonable price? and anyone want to enlighen me on this washer option so i can do that for the time being
looking at your avatar...its not a sport so i take it youve got drums on the back?
if you remove the shell of the drum...you'll have 4 bolts that hold the drum onto the axel 'the stub axel'...slacken the bolts off, and put washers under the bottom two, ....rebuild and walllarrrrr! camber ;)
Well i had my hub apart yesterday mate, and im stuck lol.. cant even get them bolts out! wat tool do i need?
its an inverted torx (femail torx) bit, if you havnt got one, youll have to buy one unfort,
ive added -va camber the same as bifcaids and couzens, just 2-3mm washers under the bottom two bolts of the drum, works fine, just make sure you tighten them up properly.
Just got a halfrauds trade card sorted out so i might have to look into getting that tool and sort it out on wednesday.
Cheers for the help guys. Baz
