Camshaft pulley tool Renault part number?!?
Car  Clio Sport 182
Hi guys, I just ordered the camshaft pulley removal tool from reno and used the part number 7711381801. Can someone confirm this number is correct as the parts bloke said it was a good number, but didn't know what it was from the description!
I've seen several numbers on the forum which varied so i just wanted to check!
there's 3 tools just for the cams
horseshoe
pulley tool
seperate cog for vvt
then you have the crank pin too
horseshoe
pulley tool
Ok, I have the horse shoe - box end.
I also have the crank Pins etc.
I believe all I need is the camshaft pulley lock tool.
Why do i need another tool for the vvt?---From the pics of the tool i've seen, it has two wheels sitting either side and in between the Exhaust and Inlet Cam pulleys?
the pulley tool comes with 2 cogs - for non VVT cars
you have to buy the extra cog which replaces the lower one so you can use the tool on a VVT engine
ok I was unaware of that!
Will renault parts dep. take those numbers. MOT 1801 and MOT 1509.01?
edit-
and just to check, aren't all 182's vvt?
I tried ordering the part using the mot number through renault
But they said the can't do that!
Does anyone have the long part number on the 1509.01 one?
