can spray diamonds???
Car  Albi blue 197
anyone here done it and what was the result??? did you sand down and primer first or did you just spary on?
Always sand down and primer otherwise the finish is gunna be crap and flake off!
use a fine scotch pad as they are kinda complicated to sand using wet and dry paper. Then use an etch or plastic primer. Make sure each coat is fully dry before applying the next.
cheer sive already started doing them and there an okay finish not the best nut decent if i can pic some up for pennies at a scappy or something ill do them again..... proply.
