Car doesnt beep when lights left on
As above but it does occasionally when u open the passenger door also interior light doesnt always come on when doors are opened any suggestions
intermittent interior light sounds like a problem with the plunger switch, which'll be somewhere around the edge of the doors or their frames
Any idea which fuse
not sure exactly but if u take the fuse cover off (passenger side) u should be able to work out which 1 it is as there are symbols on the cover., but as henry suggests could be the plunger, locate and give it a spray wd40 or something. think the plunger switch is on the frame where ur door hinges are welded
The plunger is on the bottom left corner as you open the offside door. I had the same problems so I bought a new one, took the rubber off and found it was disconnected! Why? God only knows.
