Hi all,
Just wondering if this is a common issue/trait on Clios, I have a mk 2 with stock suspension, the front seems much lower than the rear eg the whole car seems to be slanted forward a bit.
Its a DCi so I guess has more weight up front plus it does have the OEM front splitter so I guess it could look a bit lower, but it just seems that the front is lower than the rear. I think if I were to fit some different springs I am worried that the front will be far too low vs the rear being about right, not sure if its a case of old suspension making everything lower at the front or how it is normally set up?
Will measure up the heights front and rear and see what they actually are - the front splitter only just clears kerbs and I could park a bus under the rear of the car due to the ground clearance lol.
