Hi - I'm having an issue with my 182. A few weeks ago it was parked for a few days and when turning it over it would not start. no sign of firing at all. I assumed it was perhaps battery related and put it on a charger. Its a second car so not a big issue. When I went back to the car it started fine, perhaps took a bit longer than normal but ran fine. I doubt the battery charge changed anything.
Yesterday I noticed a missfire and managed to stall the car at a busy junction. The car would then just turn over. it then seemed to fire up again and ran albeit missing a bit. I was able to rev it up and it drove ok for the short trip home. I parked it overnight and tried again this morning and its just turning over again. I cannot hear any fuel pump sounding like it's priming.
The car showed no warning light, and no CEL codes. I've essentially rebuilt the entire car, engine out belts etc and in doing so cleaned well all the electrical connections. I also believe the earth straps should be fine as I cleaned and tightened them up well knowing this can cause issues.
I'm guessing based on some googling that the fuel pump relay might be playing up? I'd welcome some other suggestions.
