Car not wanting to start!
Car  Clio 1149cc Bilabong
Hi guys :D
Basically my clio doesn't want to start, you can hear it ticking over but it doesn't start until maybe the fourth attempt. Really quite annoying, I took it out the other day once I got it started and the rev gauge stopped working and my automatic lights didn't come on.
Any ideas?
Any help is much appreciated, thanks
what do u mean by ticking over but because u getting few funny faults try this an its FREEEEEE lol
there r 3 black relays in a line in the box in front an to the right of the battery on yours, when it wont start on u agen swap these around an try it. had this a few times on them.
I'll give that a try, thanks. Yeah what I said didn't make much sense lol, what i meant was you can here the starter motor cranking but it won't start :(
hmmmm.... does the 1.2 have an idle air control (iac) valve? had one of these on my vectra. started much better once i'd taken it off and given it a good clean and replaced the 59p paper gasket. that's nearly free if it has one of those.
likely culprit though is the tdc sensor. £15ish from eurocarparts. easy enough to change.
