car revs high! inlets at fault?
cs_dave
West Midlands
Hi I took my imlet off today to clean cam cover and noticed the gasket on the rear is like the instant gasket stuff. After putting it back together as is revs quite high now could an air leak from there cause this?
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
An air leak will deffo be the cause. You really ought to replace the gasket with an actual item but silicone will serve as a temporary measure
  182/RS2/ Turbo/Mk1
Because these engines run on Speed vs Density as a fuelling algorythm it means that any extra air that gets in, is fuelled for, and hence will have a big effect on idle rpm.
As Mick days, far better to clean that rubbish off and put a proper gasket on, Adam at wolves renault is a good person to get them from (he is on here)
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
I'm having a rare bit of time off however emails will be tackled tomorrow chap so if it was sent via the website I'll have a reply for you by dinnertime tomorrow.
Mick
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
I know, what a proper wrister eh! It's the first time in 4yrs I've taken Christmas off but I've had a load of calls today so I'm sure the inbox will need some pruning to so i may as well take an hour to sort folk out.
cs_dave
West Midlands
Yeh just air bag service.
it is you have brembos im like "they look good I WANT"
your engine bay is tidy im like "I WANT"
Oh now ive got an air leak lol
  182
Shoot down to Adam at Renault tomorrow or do as you said earlier about nicking the seal off the cup.
Cowboys trick using sealant.
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
Check the inlet track for any signs of leaks. The ATS and MAP sensor would be my first points to check.
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
Yep that's the one. It could also be an injector seal or even the inlet itself. You really need to start spraying stuff and looking for leaks
Chi
  Z4, VW172, R26
MicKPM the amount of time you've spent on here dishing out free advice is incredibly generous. You may as well of opened the unit ;)
