Car SOS curious cambelt change...
  2005 Clio 182
Essentially, they cut the old belt in half along the length of it, then took the outer half off, so the cams didnt move at all. They then slid the new belt on, took off the other half and pushed the new one all the way on...
Apparently it negated the need for an expensive belt change... has anybody tried this and not affected timing at all on their Clio?
McGherkin
Macca fan boiiiii
?u=http%3A%2F%2Fmemecollection.net%2Fwp-content%2Fuploads%2F2013%2F12%2Fwat-wat-wat-wat.png
What?
  2005 Clio 182
Haha! My thoughts exactly. But the cogs didn't move a MM. If you can actually cut the length of it there's apparently no need to re-time, or do anything other than take the cam-cover off...
Cowboy as anything! But it does make you wonder...
I'm also now wondering how many RB26 owners are going to try that.
  2005 Clio 182
Well in my temporary naivety, what if you oiled the tensioners... or resprung them, whatever they use....
They're plastic. They fatigue and break up.
Also, there's no way they managed to get the belt around the bottom pulley, so they'll have undone it. Which will have moved the crank without the cams.
  172 cup, Impreza P1
Exactly this! Was just going to write that. Lol, love these pish talk threads.
  2005 Clio 182
I spent seven years training as a mechanic at college too. You'd think I'd know all there was to know about this sort of thing. Silly me...
  2005 Clio 182
Yeah I did seven years. I repeated the first one seven times then I was booted. I spent a further ten years as a supply tutor. My main lesson was cambelt changes on the fly.
R3k1355
Used to be the method of choice on doing the belt on old Renault 5's IIRC.
Thinking you can do it on a more modern engine now is pretty silly.
Trying it out on an RB engine is f**king stupid tho.
I think it would work ok on an old Pinto engined Ford Cortina/Sierra, but on a modern car with floating pulleys it is a bodge job.
  MG ZR x2, Polo, CTR
The way in question is do-able, and I've done it myself but you run the risk of tensioner failure as it won't get changed.
Plus, it won't work on a F4R due to the lip on the exhaust pulley.
It only works on engines where you can slide the belt on/off without a lip on the pulley.
  Clio 172, Escort RST
It depends on who you talk to
I suggest you check this thread:
http://www.gtr.co.uk/forum/154628-how-do-cam-belt-service.html
It seems they time them up the old fashioned way.
It is iffy what Car SOS did but it is also the way many cambelts were changed. Just simply marks were how many were changed. Furthermore many people did not bother to change tensionsers in the disposable way that they did these days. With my last 944 I went to a specialist to enquire about a cambelt change who thought changing the tensioners was ludicrous. The Porsche service manual does not even mention timing up the camshaft on an S2 but I only know of specialist who does this.
My point is that whilst it is not the best way they changed it and left the tensioners it was still timed up in a correct fashion of sorts. Modern engines are a different breed when it comes to the older stuff. I guess getting the most out of the engine is one of the reasons why.
R3k1355
I'm not sure what point you're trying to make, it looks like a fairly normal belt change there??
If the RB is the same as the CA engine you usually count the teeth on each belt run to check it's timed up correctly.
Then slap it all back together and sort the ignition timing on the CAS out.
I guess I got a little lost in all of the waffle!
What I was trying to say that while it was not the best way to go about changing the belt it certainly was not as horrific as some posters are marking out.
As said it looks similar to the CA18 :).
