car still runs like crap... help..
J03
Car  MX5 1.8
yup.. after the car had its service and a new coilpack, leads and crank sensor its still glitching and misfiring now and then...
i have a backbox and i know how smooth it use to sound like when i accel.. when i do it now its like its choking.. best way to describe it is when you have a chest cough it sounds like that... like theres flem in the engine or something..
when its stationary with the engine on, it sounds like its spitting every few seconds... really doing my head in now and wanting to sell it argh!
its not the lamber sensor ive asked... but before the problem was worse!
when i had the new coils and stuf put in i took it for a run up the road and it was more fecked.. took it back to the garage.. they played with a bunch of wire and every time there is hard contact with these wires (behind the engine and plugs into the coilpack) it makes the car stall...it was wrapped in thermo tape which is basically black tape.. when he took it all off it diagnosed it abit.. but now its in its current state as i said above... anyone know what might it be and how can i possibley fix it??
bump..
i found something
when i move this pack, it cuts the engine out along with a hiss sound..
^ is there any bare wires under there? that is a very common fault! housing wants throwing away!
that metal cover in the pic comes off, where the wiring loom goes underneath it thw wires rub through and earth out! its a very common problem!
it housing is plastic, and its like a loose box.. is it meant to be like that? how can i fix it? am not sure if it will entirley fix my car but its worth a go
EDIT sorry the housing is metal, but i dont know how to get it off... its not just the housing, its the wires aswel, when i fiddle with the wires it cuts out..
IF you get w mirror down the back there is a little wheel type setup in the housing with holes in there, you have to get a pick and turn them to unthread it! then remove it, its a fiddle, may take you an hour! under there i would not be suprised if it hasnt rubbed through the insulation on a wire fella!
i dont get what you mean by this bit, does it do anyharm? iv never fiddled with my car before but its anoying now
That metal cover thats in the pick, it has a habit of rubbing through the insulation on the wires underneath! this causes them to earth out and bring warning lights on make the car run like s**t! you need to get that cover off and have a look!
same thing happened to mine. though for some reason i found the top of my metal box half way down the back of the engine. it ment to be an arsehole to remove.
So remove the top half of that black box, look for any wires which the box has been rubbing on, and tape it up with somehitng like electrical tape.
cheers pal, cars going back in on thurs, now stated as an electrical fault, so hopefully this would get it sorted!
ok il point that out to them, do you mean tape the wire as in a single wire, or the bunch of them?
