Clio 182 here.
I had an engine warning so plugged in my OBD2 and using Torque revealed the common "02 sensor bank 1" issue. Nothing operationally serious so I went to clear code, app reported all good.
Went to start the motor, which had been running fine prior to fault code clearing and it won't fire up. Turns over about 6 times and then just stops. Need to fully reset the key to go through the process again. Same thing.
Have I messed up my ECU in some way, can an OBD2 and app mess this all up?
