car wont start
hi if you keep your accelerator down will it stay on? if it is cutting out at low revs and not idling its doing the same as my car did a few weeks ago. I had to get a new throttle body.
Hmmm
I had a similar problem the other week, and it keeps re-occuring once in a while.
I took the top of the fuse box off and pressed all of the fuses down hard. It seems that some of them had come a little loose. Give that a try fella.
If you give more info people will be able to help
does it start if you blip the throttle?
Listen to the fuel pump when you put the ignition on it should hum for a few seconds while it builds up pressure
Sounds like fuel isnt making it to the cylinders
