M Mesa Car 182 (Conversion) Jul 27, 2009 #1 Hey guys, Can I disconnect the plug to this and just leave the rest safely? Or do I need to disconnect everything properly? Cheers
M Mesa Car 182 (Conversion) Jul 30, 2009 #2 Sorry to bump this, but it's dropped to page 3 without an answer. When I say disconnect the plug I mean from around the OS headlight area...but without doing anything else to it. Any help appreciated, I know it's a PITA subject so thanks.
G Gray Car M3 Touring Jul 30, 2009 #3 Yes you can unplug the canister, but it will bring up a fault code on your ECU..
J James.f Car Astra 1.9Cdti SRi Jul 30, 2009 #4 what does the Cannister do Gray? as it looks like some sort of fuel line coming off it :S
I iimushroomzii Toilet roll king Car Transit Connect. Jul 30, 2009 #5 Its vacuum hoses coming off it mate
G Gray Car M3 Touring Jul 30, 2009 #6 IIRC it filters fuel vapour and fumes through the charcoal canister, which then goes through the inlet manifold.. and is burnt off through combustion
172Ben Car BMW M3 Competition Jul 30, 2009 #7 Its big, and its getting binned when the bodies go on Ive always wondered, can you just disconnect it and leave the pipe open at the rocker cover side?
G Gray Car M3 Touring Jul 31, 2009 #8 172Ben said: Its big, and its getting binned when the bodies go on Ive always wondered, can you just disconnect it and leave the pipe open at the rocker cover side? Click to expand... I think the car would rev its balls off... similar to an air leak, but when running ITB's does it no make that system redundant ?
