Clio 182
Hi all,
So my EML is on because of the carbon (charcoal) cannister, I have sourced a heatsink resistor, bung for the inlet and a breather for the fuel tank. I've read plenty of posts about the removal of it, but there a mixed options on how to do this.
To anyone that has removed the cannister, what exactly did you leave in and what did you remove? Some say to leave the cap with the plug for the cannister and cable tie it in behind the headlight, others say remove it.
I was going to add the resistor to the plug, remove the line from the cannister to the inlet, bung the inlet off, remove the line from the tank to the cannister, and add the breather about 6 inches down this line. Is this correct or am I missing something before I tackle this job prior to its MOT?
Cheers!
Cheers!
