Cat 428 cams
Car  182 sport
Hi their just put cat 428 cams on my car without a remap and cuts out when warm is that right or is something wrong????
Well if your timings right I would suggest you get the map sorted and see after that?
Take it you mean it will stall at idle when it gets up to temp?
Yes I had cam belt and dephaser done at the same time and it was out slightly so I redid it.when the car gets to temperature the car doesn’t idle only revs then cuts out
