Cat Back Exhaust Fitting Question
Hi
I'll be replacing my exhaust for a KTec Stealth over the coming days and to save getting the car out of the garage to check I wondered what size bolts are the two that connect the centre pipe to the Cat, also what size gasket is used? Mine are rusted up so will need replacing and will replace the gasket for peace of mind.
Chris
I just use one at each side to stop the head and nut digging in. It's a solid joint with no movement.
