Cat Back Exhaust Fitting Question
Hi
I'll be replacing my exhaust for a KTec Stealth over the coming days and to save getting the car out of the garage to check I wondered what size bolts are the two that connect the centre pipe to the Cat, also what size gasket is used? Mine are rusted up so will need replacing and will replace the gasket for peace of mind.
Chris
  2xPh1, Corsa rally
M8 bolts about 40mm lenght can replace the renault ones,gasket is about £3 from euro car parts.
  2xPh1, Corsa rally
I just use one at each side to stop the head and nut digging in. It's a solid joint with no movement.
