TVR Cerbera
I have a cat bypass pipe and have tried the disconnect route..no joy and i've tried the remove the lambda route and still no joy, the light is still on.
Right my idea is to put a resistor in line with the second lambda sensor based on:
the lambda sensor gives a voltage out (0.2 - 1volt). the ecu compares the 2 lambda sensors and if the second one is lower then no light(cat working= lower emissions). so if i can fool the ecu into thinking the second voltage is lower, a resistor, it should in theory work and put the light out.
Open for discussion please.
(p.s. do i need to reset the ecu to turn the emission, not ecu, light out? and if so how?)
