Thinking about getting these, what are the cons and pros? anyone using them?
Clio 172
http://www.catcams.be/datafiles/docs/springsetup55024xx1.htm
RENAULT Clio RS O.E.M. parts CUSTOM parts / SPORT
[2.0L 16v dohc rprh]
IN EX IN EX
upper retainer O.E.M. O.E.M. O.E.M. O.E.M.
lower retainer O.E.M. O.E.M. O.E.M. O.E.M.
valve spring O.E.M. O.E.M. E99862 E99862
valve seal O.E.M. O.E.M. O.E.M. O.E.M.
fitted length / load 36,0mm / 20kg 36,5mm / 18kg 36,0mm / 32kg 36,5mm / 30kg
max. allowed lift / load 11,0mm / 67kg 11,5mm / 67kg 12,5mm / 82kg 13,0mm / 82kg
lift at spring coil collision 12,0mm 12,5mm 14,5mm 15,0mm
lift at retainer - valve seal collision 13,5mm 14,0mm 13,5mm 14,0mm
Clio 172
IN EX IN EX
