CD player/radio problem?
Car  RB 197
Bit confused by this one. When i go to eject the CD and press the button it does not eject it just turns to the radio? Also sometimes the radio just completely turns off and all that is left on the dash display is the clock? Anybody else experienced this and what may it be? Thankies
Standard update list one? Mine did it in the sunflower so just binned it. Get a cheap aftermarket one and be done with it TBH. I'll even stop off and fit it for you!
EDIT: Or you can have my standard one if I can find the code for it.
Will prob buy an aftermarket one when i have some spare cash but until then a standard one will do.
If you do find code i <3 you fankoo.
If you want the code for your standard head unit use this site.
Site: http://renaultradiocodes.dyndns-free.com/form.htm
Look on the head unit, you will have a 4 digit security code, usually starting with a letter followed by 3 numbers.
Type that 4 digit code in the code box, then just wack your email in.
Should work.
Sam!
That's brilliant, cheers Sam.
I'll sort the code out tomorrow Melly, and drop it off at Cadwell or on the way home at yours!
