central locking problem
hi guys
right gunna keep it short!! the central locking works if u puch the button inside the car but it does not work if u put the key in the door or if u use the fob on the key...
does anyone know wats wrong with it or if it will b simple to fix
cheers chris
ps... its on a mk2 ph1 1.2
Putting the key in the lock will not operate the central locking. Have you checked the battery in the fob as this is the most probable cause.
i though that if u turn the key in the drivers side door then it will lock all the doors???? or am i being stupid??
As I remember it (bear with me as I've never owned the Mk2 ph1) but I believe the lock on the door operates that single door lock only. You can sit in the car, lock the doors with the dash button. Get out of the car then lock that 1 door with the key. All doors are then secured.
thats wat i do at the moment but the fob dont seem to work at all apparently some one did try to steal it when my aunt had it!!! i dont know what damage was caused to the inside of the locks
Daz is right, the locking is single point from the remote, some of the later cars can be locked from the drivers door, if you remember the drivers door is the passenger door (French init)
i will get some batterys from hellfrauds 2moro and then see what happens yea what ever do i use the key in it only locks that door... and if my alarm goes off i have no way of turning it off... my car has a thachum catergory 2 alarm ... should it have an extra fob or will the key in the door work.
the alarm has never gone off yet
The remote on your key operates the locking the locking control module switches on the alarm. So if the batteries are flat, none of it will work from the key.
If the alarm was fitted by Renault at the point of import like the 172/182 cars or fitted by the Renault dealer, It may well be a Cat:1 Thatcham device upgrade, as combined with the factory fit immobilser, it meets the criteria for this classification.
You should have the VSIB certificate if thats the case.
Once you install your new batteries, you may need to push the button on your key, up to 5 times to resynchronise the receiver with the rolling code generated by the key.
Let us know how you get on.;)
hi guys
thanks for the help ... i changed the battery in the fob and now it works :) but im not sure if the allarm works .. when i push the button on the fob the doors lock but the indicators dont flash??
is this normal for my model (mk2 ph1 1.2)??
cheers chris
