CLIO II, KANGOO & MASTER INFRA RED RESYNCHRONISING
1. Turn Ignition OFF.
2. Press the central door locking buttonin the car for more than 5 seconds.
· Note :the door should lock then unlock.
3. When this happens, 10 seconds is allowed and the immobiliser warning light should illuminate.
4. Point the 1st key at the receiver and press the button twice, the doors should then lock and unlock. Repeat this for other remotes as required.
5. Check that the remote control unlocks and locks the doors.
LAGUNA II & SAFRANE II INFRA RED RESYNCHRONISING
2. Press the central door locking button for more than 5 seconds.
· Note : the door should lock then unlock.
3. When this happens, 15 seconds is allowed and the immobiliser warning light illuminates.
4. Point the 1st key at the receiver and press the button once, the doors should lock and unlock.
5. Point the 2nd key (if programming a 2nd key) at the receiver and press the button once, the doors should lock and unlock.
6. Check that the remote control unlocks and locks the doors.
CLIO II, KANGOO & MASTER RF RESYNCHRONISING
3. When this happens, 10 seconds is allowed and the immobiliser warning light illuminates.
4. Press the remote control once, the doors should lock and unlock.
5. Repeat for second remote if required.
LAGUNA II & SAFRANE II RF RESYNCHRONISING
5. Press the 2nd remote control once (if programming a 2nd key), the doors should then lock and unlock.
CLIO RE-SYNCHRONISING
1. Lock car manually
2. Unlock car manually
3. Insert key into ignition within 30 seconds.
4. Turn ignition and start vehicle.
MEGANE RF RESYNCHRONISING
Hold the remote control button down for longer than 10 seconds (until the red telltale light on the key extinguishes) then press it again 3 times.
Check that the doors lock and unlock correctly.
MEGANE WITH EARLY REMOTE (LED SWITCHES OFF WHEN HOLDING
BUTTON DEPRESSED)
1. Ignition ON
2. Press and hold the central locking button for 5 seconds
3. LED on the dash board will go off, come back on and begin to flash. The flashes correspond to the first digit of the 4 PIN security code - release the button when the first digit has been 'flashed' and then press the button again.
4. Wait for the second digit to be 'flashed' then release and re-press the button - continue until all digits have been entered.
5. If you have entered the code correctly the LED will then go out and the car can be started - to code the remote, switch off the ignition and press the central locking button again.
6. Press remote button 2 times within the immediate vicinity of the pick up (in the roof) On some vehicles you may need to switch the ignition back on to achieve this however.
