CF door Window Winder help?
Hi, im after a little bit of help i need to know what i will need so that i can put my windows down?
I know i need the winders, but will i need the hole system for it to work?
Heres a pic of the door (Some of you may recognize it)
Thanks Chris
  rps13
yeah i know the car mate.
funny though because a few wires would probably only be grams apart from a window winder.
would it not just be easier to get the electrics back up and running.
alternatively go to a scrappy and rip out the windows from a ph1 if you can find a windy one
  Ph1 172 + Combo van
im assuming the car originally had electric windows?
will need the whole mechanism which sits behind the door card then you need to drill a hole of your carbon fibre:eek: and mount the winder through it. best of getting it from a scrappy or go to renault and buy it.
Alastair.
  986'S 172ph1+182FF
lol at putting that panel on, now uve realised u cant operate the windows
Its already got the hole in door card ;) just need to know how to change it to winders..So all i need is the winder and the mechanism?
  Ph1 172 + Combo van
ooo lucky. yeh mate you should just need the winder and the mechanism.
best thing to do would be to go to the scrappy and find a mk2 poverty spec and steal the whole lot from inside the door card. it should be the same but maybe someone could confirm for definate.:)
  Ph1 172 + Combo van
would be good to see what the weight difference is between the electric and manual windows. most people doing a track car would normally just put the fixed windows with the slideable flap.
what wheels have you got on the car mate the black ones with the red lip?
