Changin from brakes and disks tutorial
T
thecremeegg
Following on from buying disks from halfords, anyone know of a tutorial on how to fit them to the front of my car? What do I need in terms of jacking the car up, tools etc?
is it easy(ish) for someone who doesnt really know bout such things?
Tom
Easy yep.
Get a Haynes manaul is the best way or become a member on here as there a guide in the forum members are how to do it on a 172 which is much the same.
The answer is contained in the tuning section, you need to be a member to access them.
I know there are posts in there about changing discs.
From looking at the guides to changing the front pads, is it much more work to change the disks?
Tom
Tom
If your chnaging pads then doing disk as well not much extra work just two bolt holding the caliper bracket on and two thorx bolt on the disk (if there still there). Only takes 5 minutes or so if your taking your time a side extra.
