changing brake discs
lawrence
Car  is non-existent
has anyone got a how to guide on how to change the front discs and pads on 172s please
not hard, just when the car is in the air, get a mate to put his foot on the pedal as you undo the 2 torx screws holding the discs on (dont over tighten these when you put it back together, just nip them up)
calipers arent too hard, but im too knackered to type it all out!!!!
tools needed are
13mm, 17mm, 18mm ring spanner
T30/35 (i think) torx bit
Its dead easy.
Remove the caliper and bracket (two bolts).
Remove the two nuts holding the disk on (impact driver youll need)
Push caliper piston back in.
Reasemble
There is a guide on the fum posted a while back. Just do a search for 172 or pad and it should brinf the guide up.
thats what i thought but it seems to have dissapeared, but i really need to know the discs, pads are pretty simple to change
Disks arnt much extra work you need an impact driver usually to get the disks nuts off though there a right pain.
yes, no need for impact driver mate, just do as i say above, get a mate to put his foot on the brake pedal as you undo the torx screws!!! make life MUCH easier!!!
oh and youll need a hammer to get the old discs off!!!
The only reason youll be needing a impact driver, is if some donkey has over tightened the screws in the first place, the screws arent load bearing so DONT need to be done up stupidly tight
nice one fred and edde, renault wanted £175+vat for new discs and pads and to fit aswell conning mofos
GSF fella
