Changing f fogs to driving lamps
Front fogs are practically useless in this country and I fancy swapping the units for driving lamps (a la 205 GTi) and wiring them in to the main beam switch.
Has anyone done this?
  Elise S1 B&C 140
Did it on my 218 worked well, i drew up a wiring diagram when I did it, ill try to find it the principles will all be the same.
Greeny.
  440i + 182
Sounds good, would be interested in this myself.
Should be ok for the MOT though?
thanks for the replies
i don't think that auxilliary lamps are testable (?) so that, hopefully, wouldn't be an issue
i was wondering what lamp units might fit and how to go about rewiring the stalk. i did think about splicing into the h'lamp wiring but think it'd be best to attempt to do it properly at the switch. i'm no autoelectrician (!) and am wondering what might need doing about relays and fuses etc - ? would any of the wiring need beefing up?
  FF 182, K5 GSX-R1000
Dunno what the looms like under there but id imagine feeding the front fog switch by the full beam one would be straight forward. This way they can be isolated, or when in 'on' position, auto come on with full beam. No relays or fuses would need altering/adding.
could you put fogs in and then take the 2 wires from the back of the fogs and give them contact with the full beam wire so that when you flash your full beams they come on 2??
