Changing front & rear discs - socket sizes?
  ex Clio 172 owner :(
Had a scan about on here and a little bit confused as to socket sizes.
I'm going to buy some new ones as mine are a bit mashed.
I think I need for the front:
13mm socket, 17mm spanner for the caliper piston part. Can someone confirm?
What about the size of the socket for removal of the caliper rail thing?
For the rear:
Not sure what I need. I think it's 18mm socket for the caliper. 30mm or is it 32 for the hub? Anything else?
Thanks very much.
IMO get a new socket set not just the ones you need.
30mm for the center nuts make sure you've a good socket set to get them off as there often a bit tight plus use a breakers bar also remmber some lock tight etc to ensure that if your going to reuse it (against recomendations) that it doens't come off.
cheers edde. Just gonna borrow my mates set and axle stands.
What's a breakers bar by the way?
