changing front speakers
Martin_172
Hi im thinking of changing my front speakers in my 1,2 16V for 13cm comps but im right in thinking this means i need an amp?
how are the tweeters in the clio connected? is there a crossover? or do they "piggy back" to the mid/low drivers?
anyone fitted comps into a clio? was it an easy enough job?
fitting any speakers is reasonably easy, no you dont need a amp , providin u have a decent head unit. but if u like yer music very loud a amp would be better.
if theyve got a corssover then the sound clarity will be better
volume doesnt bother me to much, i prefer sound quality. will an amp sound any better than my head unit? (Pioneer DEH-P8600MP 4X50Watts (27watts rms i think!))
also, how do you wire a set of comps to the head unit amp?
sorry im new to all of this :oops:
with no amp
heasd unit - crossover - speaker
- tweater
if u use a amp
head unit - amp - crossover - speaker
- tweater
id like to if possible get the tweeters behind the standard grills, also where have you guys hid your crossovers? is it possible to get them behind the speakers, behind the door cards?
you could get them under the dash somewhere.
i fitted my tweeters in the oem positions, i had to glue them but there are in there
Dont see why not. I guess youd simply run shorter wire from the amp to the crossovers and run two sets of speaker wire to the front for each speaker/tweeter.
