Changing spark plugs
Burp you rascal. I think its just a case of pulling of the ht lead and then using a socket extention remove the plugs. If you do it 1 at a time so you don't mess up the firing oorder.
Can't be any harder than the 172, although my friends dad thought i had taken the cylinder head off when i was doing it lol.
Basically the same ..pull the hts out..1 at a time so you dont get them muddled..get the plug remover tool ( A1 moter store sell them for about £5) and remove and replace plug.
make sure you push the ht back on snug.
tbh if you need a guide for doing it you shouldnt attempt it imo.
just look at the engine it becomes blatent.
what pinky has said is pretty much as much of a guide as you need
The lead on top of the spark plug itself, which connects to the coil pack it called the H T lead, there are 4, 1 for each plug.
Recomended are champions but you'll be fine with either bosch or ngk, whichever you can get hold off.
there seems to be some kinda oil round were the ht leads pull out... on 2&3 is this bad...? 1&4 dont
