changing standard gear knob
Car  Mk2 Clio
i've bought a momo twist on gear knob but am having trouble taking the old one off, any one got any suggestions on how to remove it? thanks
Hacksaw, molegrips and alot of swearing, im afraid mate, the std one is glued on and a pain to remove
10 minute job. use a hacksaw and cut a + shape in it then it should be okay to twist off with either mole grips or your hands
I used a thing which was a rubber strip & a handle which you could adjust, it grips it & won't mess it up. It's along the same lines as an oil filter chain removal tool. Got it from b&q.
Yeah that sounds like it, I never used it for an oil filter. I guess it does those too though.
Can peal back the rubber from the old one..then use a big wrench type thing to twist the hard plastick bit off inside..it has smelly fish glue holding it on. sorted takes 5 mins :D
