Changing to Standard Battery
rctempire
What has anyone done to convert the postive leads on the mark 1 clios to fit onto a "standard" battery terminal?
What parts did you require without cutting existing leads?
Is there a conversion kit as such for this job?
  Lots of Alfas
What type has your car got as I think theres 2 for Clios, thinking about it there should be a way to fit it onto a standard terminal, have you took it apart and had a look?
rctempire
I am wanting to swap my renault battery for a "normal" car battery. IE do away with the screw type terminals to the clamp type. As the battery is about a third cheaper to replace.
