Cheap tyre gauge.
dann2707
I have a mechanical draper one. It's nice as it has a push valve on it that you can depress to let air out.
What I like about it is that there's two parts, one that you hold on to the tyre valve with one hand and then you have the actual gauge in your other hand which allows you to have it exactly where you want for reading purposes.
I've used the fixed ones like what you linked before and they can be really awkward to use based on where the valve/wheel is positioned at the time.
Draper 69924 Tyre Pressure Gauge with Flexible Hose https://www.amazon.co.uk/dp/B0002GV286/?tag=cliospnet01-21
MarkCup
100% this. I've had one of these for 10 years now, durable and robust. Both ends rotate freely on the hose so it's super easy to use.
