Ultra 197 ex 172 Cup
Wheelman
You are here: EXTREME : WHEELMAN : WHEELMANEXTREME
Wheelman
WHEELMAN: A motor and frame supported at each end by a spokeless wheel into which feet can be inserted while standing upright. The Wheelman has a 41.5cc, 2 stroke engine which takes a mix of oil and petrol. It holds around one litre of fuel and will give you a ride time of an hour and a half or roughly 30 miles!
The learning curve of a Wheelman is very similar to surf/snow/skate boarding. So, if you have any experience in these you will be surprised on how fast and easy you pick it up.
At speed you use body movement to steer and at low speed (and you can ride a Wheelman at an extremely slow speed) you can angle the front wheel from side to side with your foot.
The speed is controlled by a cable type controller held in your hand, the more you squeeze, the more fun you have! To stop, all you need to do is let off the throttle and squeeze the brake lever. The vehicle will slow quickly but smoothly, then/or you angle the toes of your rear foot toward the ground until the pads come into contact, the harder you push the faster you stop.
This Extreme Machine is great - forget everything else, get this now!
Available in Black and Yellow only (at present)! Red and White is on the way.
WHEELMAN DEVELOPMENT AND BENEFITS:
The benefits of the wheel without axles have intrigued engineers for 100 years. Successful vehicle manufacturers have explored various design configurations and arrangements.
Now, in commercial production the wheel without an axle has a place in this amazing new machine!
It provides a low center of gravity, efficient space management, strength and a distinct weight saving that has never been seen before.
The research and development of the Wheelman has taken place over the past 20 years from the principal concept by Grant Taylor to the refinement by production design engineer Muzza Grant. This ensured that man's greatest invention has been reinvented to what we see today with the Wheelman.
Tearing up the grass, sliding in the dirt, cruising the beach. It's a Wheelman life!
Don't miss this experience!
specification
Speed 20 mphFuel Capacity 600ccWeight 23 kgRange 48km (30 miles)Engine 41.5cc stroke engine (two stroke)Transmission Centrifugal ClutchBrake Mechanism DrumLength 1m (42")Height 32cms (14")
http://www.streetgadgets.co.uk/prod/7/165/Extreme/Wheelman/Wheelman
they are only 349.95EUR
http://www.murguichips.com/wheelman-p-2349.html
anyone wanna do a group buy, to save on import tax ?
specification
