Checking Oil
Erm AFAIK no, check it when its cold and on a level surface, running the engine moves the oil round the engine and will result in a low oil reading (Erm if Im wrong Im wrong)
  Clio v6
Thanks Roamer. Ill let you know the results in about 3 hours ( when I find the dipstick hole ) :)
Rich-D
  E90 LCI 330d
Quote: Originally posted by James on 26 February 2004
Should the engine be at normal running temperature before checking the oil level ?
Nope!
If the cars been driven then it should really be sat on level ground for at least an hour before checking the level, ideally its best to do it cold when all the oil has run into the sump.
AFAIK, it is actually best to run the oil up to temp, and check about a minute or two after switching the engine off.
Rich-D
  E90 LCI 330d
Wrong...
it doesnt have to be stone cold.
a few mins after any running is fine.
You dont need to know the last ml of oil....
  Mr2 Roadster
If its not stone cold then use your noggin, dont fill it to the maximum! Simple!
