circlip on gear box
Car  clio 172 corsa turbo300hp
as above the circlips have broke on my 172 were can i get them from
renault...
But 2 things. I thought that was basically the end of a gearbox if you lost the circlip? and I'm almost certain they ditched the circlip design before the end of MK1 production??
replaced mine without any issue, circlip plus the "spacer" behind it, this is locked in by the circlip.
ben_stevo172 welded his in? could drop him a pm
I think most renault clips are the same i used 5 turbo ones, also check for damage around where the clips go in they sometimes break a bit of the lip where the clip sits into the box
The circlips were used on most boxes up until 2005.
Part numbers -
1 - 7700720854
2 - 7703066331 / 7700113257 / 8200295074 - these are all the same part but the number has superseeded a few times
They cost a couple of quid each
