Honda & VW
After claying wheels which product is best to apply after before applying wheel sealant or can this be applied directly after?
Polish lad. SRP, 203s, Lime Prime etc.
Wheels are painted, therefore (in short) care for them in the same waySo wash, clay, wash, dry, polish, seal.
Obviously a hi temp sealent, however, due to the heat the brakes create. Something like Poorboys Wheel or FK1000p.
Sod that! Proper clean, (Bilberry or Wheel brighener/tardis) and then wax! No need to clay or polish unless they are properly contaminated..And if they are, you'd be better off acid dipping & refurbing!!
problem is small bits of contamination really show up on mint silver alloys so i am keen to remove this so will go ahead and clay, thanks for your suggestion though Ali
What kind of contamination? Tar, brakedust, iron flake? If you know what it is, then i'm sure somebody will be able to suggest a product that ensures you don't grind and freeze your fingers off!!!
Braver man than i!! lol. The polish washed mine on Sat! Needs a respray anyhooo!
