DomP182 Car ph1 172, Arctic182 Mar 14, 2020 #1 Short of vapour blasting or similar is there anything I can use to clean up the white corrosion on cast alloy parts? The parts I want to clean are too fiddly to rub down with fine wire wool or auto sol really, I wondered if vinegar or a similar acid would work.
Y youngarthur Car Clio 197,with megan' Mar 14, 2020 #2 I used an electric drill, and a small wire brush attachment, on the end of the extension. I do this about once a year.
DomP182 Car ph1 172, Arctic182 Mar 14, 2020 #3 Cheers mate, I just gave it a scrub under the tap. Only a battery tray so not really seen
NorthloopCup ClioSport Moderator Car Alien Green 200 Mar 14, 2020 #4 @DomP182 http://www.raceglaze.co.uk/car-care...ace-glaze-alubright-aluminium-engine-cleaner/
