clear side repeaters
Car  F56 MINI Cooper S
I would like to fit clear reps to my 02 clio. Could someone tell me if these are the right ones and will they fit my car? Also, how do i fit them, is it hard to do all of the cables?? thanks
yes but is it as simple as just stick it back in and it works? normally when i do an "easy" job it turns into a nightmare!
It's easy to do, there are a lot of threads on here (TM) about changing them over etc.
Theres an indentation on the top of the repeater, use a credit card or protected flathead screwdriver, ease it out.
Then when it's popped out the hole, twist the holder behind it to release the big cover and then you can get the bulb out too.
Replace the bulb either with an orange or silvervision and then twist the new clear repeater on and push it back in the hole.
Job done.
