Hi, i have a clio 197 and just the other day i parked up after work to find smoke and sparks coming from the washer / radio control stalk, i immediately turned the car off and set to work to find the problem, after taking the dash apart i found that the washer stalk box was fried so i purchased a new one and fitted it with no problems (plug and play) everything works with the new control but I've lost power to the washer motor and climate control and must remember to switch the radio off when i turn the car off (it used to stop when i open the door). Has anyone else had this problem or know what i could do to fix the problem. Thanks. David197.
