I was thinking it would be the simplest option. I've removed the air on and fitted a Cup blower which I found out doesn't work with the CC loom. I'll be changing the engine loom to a Cup item as I'm removing the ABS.Why would you want to keep the panel? (Genuine question) It won't do anything apart from light up and display a temp/control fan speed. If you were going to the effort of putting in a Cup/manual heater box why not just put in the control panel amd mod the existing loom. If you wanted it to all work then you could just do a cabin loom swap and then carry out the required network config or you could just tie in the Can H and Can L then add the cabin temp sensor wiring (which is needed by the panel as that is the HVAC controller not the UCH).
Any tips Mick?To do it properly yes but there are always ways do do things ;-)
It's a track car Buddy. Weight saving is key!Mental.
climate is far superior
