SharpyClio
To give you all something to scratch your heads about, I've spent some time trying to sort out the heating / cooling in my car. The basic issue is that whatever you have it set to at start up is what you then get. So if its on hot you get hot, if its on cold you get cold. So far I have done the following,
- Done the "zip tie" fix although mine was okay
- Replaced the actuator, although I think this was okay as well.
My testing has led me see the actuator working as I start the car with the actuator out and it spins around to the setting you have, so hot or cold, however if you then change the setting it seems to try to move but it doesn't just sweep round as I would expect it kinda seems to go notchily if you see what I mean where it goes a tiny amount at a time but never gets too far before it stops.
So on that basis I am kinda out of ideas, the flap works, the actuator works, the control panel works (on the basis that I have put another one in and its the same) but the system doesnt seem to work as I would expect, any thoughts?
